z650SR D3 clutch switch - Kawasaki Motorcycle Forums
post #1 of 3 (permalink) Old 04-10-2019, 05:36 PM Thread Starter
Junior Member
I am looking for a new clutch switch part number 27043002 no longer available with Kawasaki.
Can you buy aftermarket or do I have to pay through the noise for one on ebay.
Regards
Trevor
trev the rev is offline
Sponsored Links
Advertisement
post #2 of 3 (permalink) Old 04-10-2019, 08:44 PM
Senior Member
martin-csr's Avatar
You might be able to find a good used one on EB >> many KZs had the same switch. For a newer part you might be able to use the switch from a KZ1000-P Police (82-2005) if any of them have its wiring separate from the control housing wiring. Buying the control housing for the switch is probably going to be more expensive than getting the NOS part #27043-002.
I don't know if there's anything new/aftermarket that you can use. I checked Z1Enterprises dot com but didn't see anything.
Another option is to swap out the clutch perch & clutch lever from a ZN700 or some other model. The ZN700 had a switch that was used on many modern Kawasaki motorcycles.
martin-csr is offline
post #3 of 3 (permalink) Old 04-11-2019, 09:05 AM
Senior Member
martin-csr's Avatar
Are you in the UK? I saw a new aftermarket GPz 550 D1 clutch switch listed on EB-UK for pretty cheap.
I guess it's the same as the 650-D3. ??? In the USA the 550-D1 & 81 KZ650-CSR had the same switch.
Addendum to previous reply: after more careful checking, all of the KZ1000-P models had the clutch switch wired with the handlebar control & the models after around 1997 had a modern type of switch similar to the ZN mentioned. From EB pics the ZN700 clutch perch is physically similar to the 650, but I don't know if the clutch levers are the same or swappable for oem fitment.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
