slight rust in fuel tank - Kawasaki Motorcycle Forums
post #1 of 12 (permalink) Old 08-01-2019, 01:31 PM Thread Starter
Senior Member
I just noticed on my kz440ltd when I opened the fuel cap for the first time a slight coating of rust on the surface under the filler neck. it's just so very slight to the point it rubs off my finger. is anybody here aware of any kind of solvent/additive I can add to the fuel tank to slowly dissolve this coating? I'm talking about something I can just add to the gas to slowly clean out the tank while I ride. it's not nowhere near necessary to remove the tank for this. I can almost leave it alone really....
saturnsc2 is offline
Sponsored Links
Advertisement
post #2 of 12 (permalink) Old 08-01-2019, 07:58 PM
Senior Member
Keep it filled and ride it a lot and the rust will be washed away by the gasoline I'm sure. Install a filter in the fuel line between the tank and the carbs.
You can drain the tank and fill it with this stuff to clean off the rust if you want.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
1985 Kawasaki ZN700 Shaft, 4cyl
1989 Yamaha Venture Royale
2007 Yamaha Royal Star Venture
RoadRunner322 is offline
post #3 of 12 (permalink) Old 08-01-2019, 08:28 PM Thread Starter
Senior Member
the metal's just a rusty color no heavy rust ot scaling. it probably will do the trick to just fill it & ride. the fuel tap has a screen in it I believe to catch any debris...
Sponsored Links
Advertisement
post #4 of 12 (permalink) Old 08-01-2019, 11:51 PM
Senior Member
A fuel filter will filter much better. Just make sure it is free flowing so it won't starve the engine at high rpm. One of the first things I did to my ZN700 was to install a filter.
post #5 of 12 (permalink) Old 08-02-2019, 12:25 PM Thread Starter
Senior Member
I looked into the gas tank yesterday with a bright flashlight for the first time & I did see some accumulation on the bottoms. I'm not sure if it's rust or some other kind of accumulation. it almost looks like something else. does gas leave deposits after a long time? this bike sat in a heated garage covered for 30 years....I can't see how the tank could rust on the bottom which is covered by gas all the time...
post #6 of 12 (permalink) Old 08-02-2019, 03:18 PM
Senior Member
My ZN was 24 yrs old with only 1k miles on it when I bought it. I removed the tank, sloshed the gas around and poured it out filtering it through a shop towel. Then I poured the gas back in and repeated the filtering. And added the gas line filter.
post #7 of 12 (permalink) Old 08-02-2019, 07:52 PM Thread Starter
Senior Member
did it have rust/debris at the bottom of the tank as well? did this take care of it? the valve on this bike if I remove the hose it shouldn't leak right as it one of those vacuum valves correct?
post #8 of 12 (permalink) Old 08-04-2019, 09:13 PM Thread Starter
Senior Member
how well does this work? does it clean the crud of the bottom as well?
post #9 of 12 (permalink) Old 08-04-2019, 10:08 PM
Senior Member
I haven't used it but a member on the venture forum uses it when he restore old bikes and he was the one who recommended it.
post #10 of 12 (permalink) Old 08-04-2019, 10:14 PM Thread Starter
Senior Member
I was watching videos on youtube with people using this stuff & it looks impressive. maybe i will give it a shot...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
