bad tach cable? - Kawasaki Motorcycle Forums
post #1 of 6 (permalink) Old 08-10-2019, 01:19 PM Thread Starter
Senior Member
bad tach cable?
I seen bad tach cables that snap & then the tach needle doesn't move at all, but on my bike a 1983 kz440 ltd I just noticed today the needle does move but hardly at all. it moves slightly up with high engine revs, but nowhere near the correct reading. can the cable be bad?
saturnsc2 is online now
Sponsored Links
Advertisement
post #2 of 6 (permalink) Old 08-10-2019, 09:12 PM Thread Starter
Senior Member
I did remove the cable where it goes into the engine & it's not snapped it's intact & heavily greased so what the **** could be goin on? bad tach itself? with only 799 miles on the bike? I spun the inner cable with it still connected to the tach & the needle barely moved....
post #3 of 6 (permalink) Old Yesterday, 10:51 AM
Senior Member
martin-csr's Avatar
Did you remove the inner cable from the outer sheathing for inspection? I was thinking that the inner cable is broken, so part of it is spinning with the tachometer drive at the engine, and the other part is making contact & spinning enough to move the tach needle. Another possibility is that the inner cable ends aren't properly seated.
martin-csr is offline
Sponsored Links
Advertisement
post #4 of 6 (permalink) Old Yesterday, 04:59 PM Thread Starter
Senior Member
it seems to be alright. I did order a n.o.s. cable for $28.00 so i'll compare them to each other. if it's not the cable must be in the tach or the cable drive in the cylinder head, but it's a 799 mile bike can't believe either could be bad....
post #5 of 6 (permalink) Old Today, 01:50 PM
Senior Member
martin-csr's Avatar
I would remove the inner cable to inspect it.
Another possibility could be a problem with the tachometer.
post #6 of 6 (permalink) Old Today, 05:38 PM Thread Starter
Senior Member
this might be in the tach itself. another person was complaining on another forum about the same thing happening & he was able to take it apart to lube the bearings & it responded. this one looks to be pretty sealed up so I might be better off just swapping it with another used one or they have n.o.s. ones as well....
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
You may post new threads
You may post replies
BB code is On
