I can turn my bayou on no problem, but it only idles on choke and i cant rev it more than an 1/8 of the way or it tries to bog down. and when i try and take it off choke it dies, help?
Go to Kawasaki.com and print a parts diagram of the carburetor from the Parts Diagram section. Then disassemble the carburetor and clean the pilot circuit. Do not try to just squirt it out or use air pressure, but take it apart and inspect each and every component to be sure they are clean. Use a good quality motorcycle carburetor cleaner that does not foam, or you will lose parts in the foamy mess.
Count the turns on the pilot screw to remove it, and put it back after the passages are clean with the same number of turns so you have a good starting idle.
After you have cleaned the carb, i would suggest buying a new plug too I had similar issues and I cleaned the carb and put in a new plug, issues resolved.
