My 4WD switch stopped having any effect and I pulled the front racks and plastic to get to the fuses up there. They are okay. I also unplugged the 4WD handlebar switch and plugged it back in. Still nothing. I put a new switch in the circuit and still nothing. I put the old switch back in and hooked it back up.
Now, the Belt warning light is flashing and, of course, I can only get up to 3600RPM, which isn't nearly enough to get up the mountain I have to climb tomorrow morning for opening day of deer season.
First I need to know if the switch in the CVT cover should be positioned forward or rearward for normal. Second, is there anything else besides the switch or the fuse up front that would cause the belt system check to flash? I know that the 100 hour setting will cause it also and I guess it could have just happened to come on while I was messing with it but that would be a big time coincidence. And even so, how do you reset the timer?
I have a two week period with no hunting after this weekend that I can take it to the shop to get it fixed up right but I really need to use it tomorrow.
Any help?
Thanks.
Jim
Any help?
Thanks.
Jim
