1 - 5 of 5 Posts
I got a thunder hurricane and a Techlusion TFI module for Xmass. I installed them on the bike and now the bike won't idle smooth. It sist there and surges between 1500 and 2000 RPM. It still does it when I unplug the TFI. Any ideas WTF is going on? If i try to tune it with the TFI I can get to run smoth but only at 3000 rpm! :-| :? I would not consider this idling!!!
Thanks for any help!
It sounds like there is a leak. Perhaps the intake system was not installed correctly. I suggest double checking the installation.
yep, sounds like a vacuum leak. as ppark said double check the install. did you plug the two vacuum lines right behind the breather?
Got it fixed. I did plug the vaccum lines but turns out one of the plugs was no good. I did it in the driveway after dark so visibility was limited..........took me 5 minutes to fix this morning. Thnaks boys.
1 - 5 of 5 Posts
