05 ZX10r wont start
3.3K views 9 replies 4 participants last post by  jtalbert
#1 ·
My 05 zx10r wont start. When I turn the key the fuel pump does not engage and I notice the clock resets itself back to 1:00.
WTF ????:confused:
#6 ·
Low battery voltage could cause this. Should be over 12 volts. You can also take it to auto parts store and have it load checked to see if it's any good or not. If the battery was not properly initialized when the bike was set up, it may be at the end of its life.
#8 ·
I have a 05 zx10r that wont start. When I turn the key it tries to turn over but nothing. Not even the fuel pump comes on. I also noticed that the clock resets itself back to 1:00. I have checked the battery and the voltage reads at 12.4. I''ve also checked the fuel pump connections and tey are tight. The bike ran fine about 1 week ago, prior to lowering with extreme links. Any help would be greatly appreciated.
HOTT MC
#10 ·
HOTT MC
raise the tank, get a simple light test and see if your getting any voltage to your pump. you can test the plug or keep it plugged in and poke the power wire to your pump to see if your getting any juice. start there and post back
