1 - 2 of 2 Posts
bike has been changed to manuel clutch now acts like all gears are gone like every where is neutral ,,,can this be as simple as a clutch adjustment thanks to all
Knows more than he needs
most likely that your cable isnt adjusted properly. when you put it in gear and go to take off, does it move at all? most times it will go but very slow and seem to rev up really high and go nowhere fast. if thats your case you need to lengthen the cable a little bit to let the arm return all the way and completely engage the clutch
1 - 2 of 2 Posts
