1 - 10 of 10 Posts
:mad:
Ok here is what I have going on.
2007 Kawasaki KLX250s - 13k mi. Bike ran and rode great when I got it. Fixed quite a lot as the bike was not well taken care of. Installed a headlight cut off switch, fixed turn signals with a new relay, fixed tail and brake light, checked fuses, new ignition switch, new battery, carb cleaning, and I am sure I am missing more.
Now I have no spark!
Bike turns over with no problem, i have all the voltage at the run stop switch, pickup coil is at 230 ohms (280-180 Ohms), stator checks out, coil shows an even of 5.56 ohms on both primary and secondary(think here lies the issue, (HOWEVER, I HAVE NO ILLUMNATION OF MY TEST LIGHT AT THE COIL CONNECTION AND NO SIGN BUT .2 v there. The CDI was replaced and I still have the old one.
I tore the harness apart and had continuity between the CDI and coil wire.
Is there something else in the mix that I am freaking missing???? Pulling my hair out..
HELPPPPPP
Discussion Starter #2
Re: Non Start 07 KLX250s.. CDI INFO NEEDED>> HELPPP
TRULY NEED A VERY FLUENT KLX/KLR KAWI TECH!!
Ok
Here we go again.. No voltage to the Blue Coil Wire. contunity to the CDI. - New CDI.... I AM LOST!!! TRULY THINK THERE IS A LEAD THAT DOESENT HAVE 12V and/or cant find whats missing here.. Pulling my hair out.
JUST TESTED EVERY CIRCUIT AND ACCESSORY..
Horn - OK
Brights- OK
Gauges - OK
Turns - OK
Starter System - OK
Brake/ Tail - OK
Cooling Fan circut - OK
Gear Position Switch - OK
On/ OFF Switch - OK
Ignition Switch(NEW) - OK
LOW VOLTAGE AT BLUE CDI to COIL/ Tach Lead - off (.5V and Turning over (-2.8V)
AL OTHER CDI WIRES CHECK OUT FOR CONTINUNITY AND VOLTAGE!!
SAME (.5 and Turning Over (-2.8V) at Coil wire and Tach.
STATOR Checked out at 4.7V Each Leg.
Voltage Regulator Drops Brown Lead from 12.5V to 8V at crank over.
SOLID GROUND AT MOTOR, FRAME, and all Leads.
LOOKING FOR A 2006-2007 KLX250S ONLY WIRING DIAGRAM>
I am using a KLX250H6F One. Closest I have been able to find...
Discussion Starter #4
Inbox me with what all you have tested, replaced, inspected, checked.. anything that's not working in the electrical system etc.
Discussion Starter #7
When you turn the key on do you have 12V @?
1. CDI Hot Wire
2. Coil blue led? when cranking
3. Ignition Switch?
4. Start on/off switch?
5. Headlight?
6. Turn Indicators?
7. Tail light?
8. horn?
9. Brake Light Switches?
Are critical to make sure there is voltage and GROUND both... I need to know
Discussion Starter #9
so the bike runs?
Have you changed anything out??
The point is... You came to this link to get help about what is working and not working and how to fix your bike so it works. I am donating my time and Experience and your not helping me or YOURSELF in this situation.. Your answers have not helped YOU figure it out.. So until there are answers to the complete questions that I am asking about the bike I am going to ignore your response's.. Best of luck..
Hi was there a solution to this problem? I have the exact same scenario. A resolution to this post would be great. Thank you
1 - 10 of 10 Posts
