1 - 1 of 1 Posts
Ok have just acquired a 07 mule 610
Only 30 hrs on unit , but not sure any
P M s were done . ( old farmer).
all is good until you use it in 4wd
then a little while after taking it out of 4x4
It starts a scraping noise.
So far , found all boots in place , no obvious play in any u- joint. Only found
Up /down, side/side play at yoke in front of carrierbearing where front drive shaft slides in/out. Little boot/seal loose , rust in splines. Could this make all that noise?
1 - 1 of 1 Posts
