1 - 12 of 12 Posts
Are the boots that go onto the spark plugs supposed to be really hard to remove???
I tried getting them off to check the plugs, and got worn out just trying to remove one of them.
Is there a trick to getting them off easily???
You gotta work em Baby.....:)
Twist and pull up with determination and the will not to get beaten..
DO NOT LEVER THEM IN ANY WAY............ or it will end in tears..:(
The Cruising Gunsmith
They tend to stick after they have been on a while.
some can be very hard to get out.
I know you have to do some crazy work to get them out of a ZX14.
The will not to get beaten? I think the bike has the advantage there. All it has to do is just sit there, I'm the one doing all the work! :)
Na you not on your own, Them's right tarts to get out when there welded, Glued & Roasted in..
Get yourself some release agent in a spray can and spray around the point at which they seal around the Spark plug tunnel and leave to soak in for about a week then repeat !!!!!!!!!!
Ok not a week but as long as you can stand to wait.........:)
WD40 or Duck Oil if either rings a bell ??
NOT seafoam thou that's only for the Idly rich with running issues..
Blasphemer!! you are going to get the seafoam gods angry. LOL
ALL
HAIL
SEAFOAM
GODS....!
There that should do the trick :biggrin: :biggrin: I hope.....:eek:
I wounder with child like curiosity if there is a SeaFoam Heaven, And profuse users will secure their seat ?????
1 - 12 of 12 Posts
