1 - 14 of 14 Posts
Hi, new Kaw owner and forum n00b with a possibly stupid question.
The bike in question is a '77 KZ1000. The only thing resembling a VIN on it is a 12-digit code, printed on the mfr label and stamped into the frame where a 17-digit VIN would normally be: KZT00A-012273.
Buykawasaki says that's not a valid VIN/HIN. The bike has no title (plate expired and bike abandoned in 1984, sat in storage until 1997, last owner never bothered to title and reg it), so I can't go by it. Using Uncle Bob's decoder, I've almost developed a 17-digit VIN for it: JK1GU71A?7?012273. Not knowing the check digit or the factory location code, I can't go any further... and it's not on the frame in that form anyway.
Little help here?
hey, new Kaw owner and forum noob myself, heh
I don't think the 17 digit VIN standard came around until around 1980 but I may be wrong. My bike is a '73 and the VIN/SN is Z1F-41288
by the way I have the same problem as you, this bike hadn't been registered since '87 and there is no title anywhere to be found. I do have the plate that was on it in '87, I'm hoping that will help some.
try
KZT00A sounds right for a kz1000 and the A for a model then the 6 digits. frame number should still be on the head stock. and vin range for that year is
KZTOOA500001 - 507026 for the Amodel. usa mfg
KZTOOA000101 - 026623 for the A model japan mfg.
so everything does seem in order. if you go to the dmv they should be able to pull it up. you can also take your engine number, although i dont think it will help. that is located under your carb on the rh engine case. should be fairly obvious. it should be in this range KZTOOAE000101 - 41170.
hope that helps
matt
Hello gents,
Insurance gave me no hassles at all concerning the VIN, and the verification place didn't look twice, except to comment on how good the bike looks for its age. DMV may be another kettle of tripe entirely.
Thanks,
Coinneach
I have the same problem, new to road bikes (always had a bike to ride the fields growing up but first time trying to get a bike legal for road use) I on the other hand have the title, the title says the vin is KZ750H009845, I had the bike plated a couple years ago and insured too, but then I put it in storage and just getting it back out, tried calling the insurance company and they say its not a valid VIN, but said just bring the title in and they will make a copy of it just in case there is any question about it being a valid VIN, and somehow I had it plated before so the DMV must have accepted it as a VIN before...
KZ Kool!
I'd bet you just caught someone whose inexperience caused them to dismiss your VIN without bothering to look it up. All these older bikes have a shorter VIN and there is no way to make it longer. :D
- Nate >>
You are right about 12 digits before 1981 by the way. Question if anyone can help the VIN number is
KZT00B529346
I know it's a 1980 kz1000 but it's it a classic, kz1000 B4 lmtd. We are trying to sell and have title but no luck on finding what we need in that. Was purchased by my deceased father n law from somewhere in California so don't know of the dealer he bought it from. But if anyone could help me decode this VIN I would greatly appreciate it. 😊
Zedder dot com has frame & engine number info for the 1980 KZ1000-B4 LTD. The number you posted fits into the VIN range. Also, the Kawasaki service manual supplement for the B4 has the beginning engine # & frame # in the contents section near the front of the manual. Some EB sellers include a pic of the page which also has photos of the motorcycle. For example see EB item 362368625979.
I have a 1985 z550 and it only has a 12 digit code on the head stock. That same code is on aLL the stickers as weLL.
Did VINs used to be printed somewhere eLse? The bike is obviousLy oLder than 17 digit VIN.
try
hope that helps
matt
yes i whant to now as wel my vin is also a 12 diget nomber and it a kawazaki 1100 zzr why cant i find it if i try to do vin check
Administrator
The Kawasaki service manual for your bike has serial numbers printed on the back cover. You can try asking your dealer, but they may or may not want to bother looking that up for you. May I ask why you want to check the numbers?
1 - 14 of 14 Posts
