681 - 700 of 719 Posts
New member here...Just picked up a 2003 Vulcan Nomad 1500..My first cruiser...used to have a crotch rocket many years ago...I've been spoiled driving my girls Harley...but she got tired riding b*ch on her own bike..LOL
I love the bike so far....lots of power, heavy and solid on the road and handles like a dream.
Here's a pic.
· Super Moderator
Here's a pic.
Nice! Question tho- are you sure it's a 1500? I can't read the air cover sticker but I thought the 1500s had a single front brake disc and the 1600s were dual front disc. Just curious...
2 Air Cleaners, Is it a Classic
I have a few questions about my 96 Vulcan 1500?
When I enter my VIN into various sites online it says its a VN1500D, but when I look for parts the only D I find is a "Classic"(which actually lists as a VN1500D1?) my bike doesn't have any Classic badging, how can I tell?
Also it has an air cleaner housing on both sides but only has an air cleaner element on the left side, right housing is empty? Was considering using the existing cleaner element (that I'm about to replace with a K&N) on the other side? thoughts?
I thought I saw a kit to replace the unused housing but now I cant find it anymore?
Thanks for the help, and for a great place to discuss issues w/ other riders
Mike
Re: 2 Air Cleaners, Is it a Classic
Correct me if I'm wrong...but the model designations are as follows:
1500A-original 1500 SOP ~1985
1500N-Classic with carburetor
1500D-Classic with FI
1500P-Meanstreak
I defiantly don't know a lot about these bikes, but when i enter my VIN into any online site it shows it as a VN1500D and I know its carb, not FI(did the offer FI in 96?) I did find the designation of "Classic" on the bottom of one of the badges so I'm fairly confident its a classic, but thanks.
My other question is still bothering me, I have 2 air cleaner housings but only 1 has an element?
I put the E3's, and K&N in yesterday, it does seem to run a little better but i didnt do anything with the other air cleaner housing on the right side of the bike, anyone have any suggestions?
thanks again
mike
Sorry about the mis-information with the model designations. Goes to show...not EVERYONE in a forum knows everything. To answer your other question pertaining to the air cleaner...yes, there are 2 sides to the air box, but only the right side contains a filter element. The rest of it is to muffle the intake noise and to make the bike look "symmetrical" and also to hide the coil packs and a lot of other "ugly" stuff. You can completely remove the whole air box and install an aftermarket air cleaner directly to the carb. This would require that you remove the fuel tank I believe.
thanks kcarlson1979
that's exactly what i was hoping to hear! except mine has the element on the left side of the bike? should i put an element on the missing side, as i now have an extra? is there any advantage/disadvantage?
· Super Moderator
kcarlson1979 thanks for the breakdown, and rbentnail very creative solution (there might be a market for the bracket??)
but as long as i understand whats going on, and that there's nothing wrong, i kind of like the symmetrical look.
thanks to all, and i will post a E3/K&N performance update after i run a few tanks of gas thru it
mike
· Super Moderator
The breather I installed at the time wasn't all that different from the OEM. Besides, you only look at one side a time :). It wasn't a real popular model but I liked it. Don't think it can be had anymore.
94 Vulcan 1500 88 starting problems ( of course)
hey im hoping anyone can help, I recently acquired a 1994 vulcan 1500 88 and i replaced the solenoid and at first it seemed like it wanted to crank over but the battery i was using was not adequate to handle the cca this particular bike requires. so i went to local wallyworld and got the es50n18la3. Needless to say it just didnt seem to work of course the twist throttle on the handle bar breaks cheap plastic but also this bike was sitting outside for a while so i guess its expected. So what happens now is when i turn on the ignition i get one click and thats it and thats all. Im in the process of cleaning all my connectors with my dremel and making sure all wires are connected correctly. anywho any help is much appreciated, I also cleaned the right throttle start button and kill switch housing assembly
