re
05 FI specs-
Displacement 1470 cc Bore & stroke 102.0 x 90.0 mm Maximum Torque 83.9 lb-ft @ 2,800 RPM Compression Ratio 9.0:1 Fuel injection Mitsubishi Ø 36 mm x 2 Transmission 5-speed Charging System 42A x 14V @6000 rpm Rake Angle 32º Front Wheel Travel 150 mm (5.9 in.) Rear Wheel Travel 95 mm (3.7 in.) Front Tire Size 130/90-16 Rear Tire Size 150/80-16 Wheelbase 1665 mm (65.6 in.) Seat Height 700 mm (27.6 in.) Fuel Tank Capacity 19 L (4.2 gal.) Dry Weight 299 kg (659 lb.) Warranty 12 months GTPP 24 or 36 months MSRP $12,499
05 1600 specs-
Type 4-stroke V-Twin Displacement 1,552 cc Bore & Stroke 102 x 95 mm Compression Ratio 11.3:1 Valve system SOHC, 8 valves, automatic hydraulic lash adjustment Fuel injection Ø 36 mm x 2 Ignition Digital Starting Electric Cooling Liquid Lubrication Forced lubrication, wet sump Engine Oil: Rating API SE, SF, SG, SH (with JASO MA), or SJ (with JASO MA) Engine Oil: Viscosity SAW 10W-40 Engine Oil: Capacity 3.5 litres Spark plug DRP6EA-9 Valve timing: Inlet Open: 28° BTDC;
Close: 72° ABDC; Duration: 280°
Exhaust Open: 66° BBDC;
Close: 34° ATDC; Duration: 280° Charging current & voltage 42 A, 14 V @ 6,000 rpm DRIVETRAIN Transmission 5-speed, return Primary drive Gear Final drive Shaft Primary reduction ratio 1.517 (85/56) Gear ratios: 1st 2.500 (40/16) 2nd 1.590 (35/22) 3rd 1.192 (31/26) 4th 0.965 (28/29) 5th 0.781 (25/32) Final reduction ratio 2.619 (15/21 x 33/9) Overall drive ratio 3.105 @ top gear Clutch Wet, multi-disc FRAME Type Double-cradle, high-tensile steel Suspension, front 43 mm telescopic fork Suspension, rear Swingarm with twin shocks with 4-way rebound damping Wheel travel: front 150 mm Wheel travel: rear 95 mm Tires: front 130/90-16M/C (67H) Tires: rear 170/70B16M/C (75H) Caster (rake) 32° Trail 177 mm Steering angle (left/right) 34.5° / 34. BRAKES Front Dual 300 mm discs Front calipers Dual twin-piston calipers Rear Single 300 mm disc Rear caliper Twin-piston caliper ELECTRICAL EQUIPMENT Battery 12 V, 18 Ah Headlight (high/low) 12 V, 60/55 W Tail/brake light 12 V, 5/21 W DIMENSIONS Overall length 2,505 mm Overall width 980 mm Overall height 1,150 mm Wheelbase 1,704 mm Ground clearance 130 mm Seat height 681 mm Dry weight 315 kg Fuel capacity 20 L
high marks for 1500 come from its history as being a very reliable bike,its been around a number of years -i'm sure the 1600 will prove to be equal
