check this:
left side air cleaner-there is a metal plate that bolts to the engine,the air cleaner housing
bolts to this plate-remove the a/c to expose this plate-check the bolts holding it on
they may be bottomed out not fully tightening this plate in place-at certain rpm's
this plate will rattle and or chirp.install a couple of flat washers to the bolts and it will stop
just though i'd pass this along-mines ok :wink:
other rattles:
speedo housing-remove and place some foam rubber inside along the sides
headlight bucket-open up and ziptie or tape down wiring so as to not rattle against bucket
other rattles:
