ok fellas,how bout a little input?
what tire pressures are you running on the 1600classic?
mfg owner manual says-28psi front/36psi rear
tire says-41psi front/41psi rear
shop manual says-36psi front/36psi rear
drive shaft sticker says-28psi front/36psi rear
stealer says-34psi front/36psi rear
which one do you use? of have you found your own combination?
after playing with pressures-i found my combo :wink:
