1 - 1 of 1 Posts
As we all know the changes to the 2010 vulcan 1700 bikes include:2010 CHANGES
• Improved exhaust pipe heat shielding reduces radiant heat felt by the rider
• Improved radiator ducting helps keep heat away from the rider’s right leg
• A 5mm shorter coolant pipe makes it possible to remove the pipe without removing the alternator cover, simplifying oil-screen maintenance. after much research between myself , my dealer and 5 calls to Kawasaki (including a call to Kawasaki in japan) by customer support i will quote" There is NO Needed Maintenance To the Oil Screens" so why they worded it that way is strange but at least we know it is not necessary to service them....FYI
1 - 1 of 1 Posts
