1 - 8 of 8 Posts
Is there a o- ring that goes over the sleve that the carb gets mounted to.??
I installed the carb after cleaning and its seeping fuel around the mount area.
Hmmm no there is not. But there is one on the inside before you put on the cluch cover case on. There is only the red sleve the is pressed in the backside of the hole of the carb that does go on the rotary intake tube. I have 2 1970 trailboss 100's so If ya need help just ask.
Not To Worry, I am Here.
On the KE100, there is a phenolic plastic "bushing" that fits in the mouth of the carb, over the inlet spigot. Not available at your local Kwak dealership FWIW, is this piece still there?
edit: Actually it sounds like the same piece BrianT is mentioning, the red sleeve.
Hmmm kinda wierd that it would be worn out????? I have 5 70 carbs and they are all still good. Even when you tighten it down its loose.????
1 - 8 of 8 Posts
