I recently purchased a really cherry G4TR, 2030 miles, near perfect factory paint, original seat and all. It had sat for quite some time with a half tank of fuel, but it all cleaned up nicely. A new petcock and a touch-up on the carb and it fired first kick.
It does have some minor problems: lights don't work, it had been dropped or hit on the left handlebar...it was slightly bent (an easy fix) and the replacement clutch handle isn't correct.
But the biggest problem I have is that the clutch is stuck and won't disengage. And when I say stuck, it's tight. Any thoughts, comments or ideas on how to get it loose?
Discussion Starter #3
It is the clutch. The cable and the "actuator", the part that pushes the clutch in, works fine. I can actually manually depress the clutch with the cover off, but it appears that the plates are stuck.
