1 - 2 of 2 Posts
I have a 1975 Kawa 900 Z1 that I bought new in '75. I'm having problems with one carb (it has 4) spilling gas out the overflow when bike is moved such as lifting it off it's kickstand or just bumping it. Turning the petcock to "off" doesn't make much difference. I changed the needle valve but that didn't help. Any suggestions?
Is there possibly a hole in the float, or that little pin that holds the float in place possibly got trash on it and sticking, or bent the tab that controls the float level. But if you close the petcock there should not be fuel flowing to the carbs ....hmmmm.
1 - 2 of 2 Posts
