This is where JIS screwdrivers come in handy.These are usually easily rebuilldable, but you have you get it right, or you end up with an engine full of gas inn the crankcase. Worth opening up though. Use the right size screwdrivers so you don't buggger up the threads, in case they're tight, they usually aren't.![]()
And no vacuum petcock for the KZ1000- A1 which is also listed under Partzilla 1978 KZ1000.Partzilla is showing a vacuum petcock for the 1978 KZ1000-A2 but not for the 1000-B2 Ltd.
diaphragm plate
