Thank you for the reference on Pods. Apparently my US KZ650 is a B2A model that has these unusual VM22
MIKUNI KOGYO carb. My Cylmer service manual doesn't cover this carb. Searching on VM22 comes up with a variety of dirt bikes, not mine in particular. I can't go back to the regular air box, don't have it and it is owned by my son-in-law...leaving the pods.
Last night, I read a good article describing the idle circuit, the mid range and the high end. If my problem is midrange, it is saying to change the jet needle or raise/lower the needle clip. My idle seems to be good except on take off. It bogs down. Changing the clip after each ride to see the impact is a bit time consuming. Well, put there is 3 feet of snow outside in Chicago.
The knowledge also pulled, was if the plugs show a lean condition (white hot), the main jet should be bumped up a number. Sounds reasonable. I am surprised the previous reliable service guy didn't bump up the carb jet when he installed and ripped out the air box as his recommendation. So much for the reliable guy's mode, I guess.
The needle thickness is of interest to me should anyone have experience with these VM22 carbs.
Thank for the response. Regards John
Current spec / and in use.
Main jet 90
Pilot jet 15
Second pilot jet 50
Needle jet AO-7.4
Jet needle 5CL-10-4
