I have run into problems with my Gunsons tool. It is a 12mm thread and my KZ650 is 14mm spark plug size. I don't see an adaptor from 12mm to 14mm, just the other direction. Bummer.
Carbs reinstalled. Previous owner's INA pods used because the Moxi new ones seem to cover the intake holes. Chicago temps cold 20 degrees in the garage/shop. New rubber intake boots. I replaced the Phillips JIS screws with Alan headed screws. Much easier to tighten. Used zip-ties to support the back end of the carbs since it is missing the standard air box.
Engine started with a little kick starting and work. No gas leaks out the bowls. Gravity fed fuel line. Choke full on at first, then backed down part way. Engine popped a lot. Had a hard time idling when warmed up some with out stopping. After running at 4k rpm (where I could get it) and going through a 1/2 pint of fuel, I used some Mystery oil deluted through the system. Sometimes I use Sea Foam just to "oil" it up some. I knew it had a lot of wd40 inside. Then I go back to regular 87 fuel. Popping stopped/slowed down some. I think cyl4 is too lean. I controlled throttle with the choke lever. If I tried the throttle grip twist, the engine bogged down regardless how slow I turned the throttle.
Engine got hot without much air flow. cyl1-250, cyl2-250, cyl3-300, cyl4-600. Seeing that, I shut it off and check plugs. Plugs 1 and 2 looked pretty good. Not carboned up and a little wet on both. Cyl3 a bit lean (maybe perfect) with the to ground electron wire white on the tip. Rim was white dry. Cyl4 was white across the full top of the ground electron wire. White and dry on the rim. Sorry no pictures.
Think cyl4 was lean (temp high, white on full tip), I turned out the fuel mix screw. "Out" to me is turning-to-the-left. It is a pointy fuel screw close to the engine. So I think that will put in more fuel. Anyone....correct? It was originally 1 1/4, it is now 1 1/2 turns out. I did not change cyl3. Screwdriver doesn't fit under the carb. I have an old one to cut up.
Picture added. The fuel mix screw I turned out is the top one. I turned it to the left 1/4 turn. So I have cyl 1 thru 3 at 1 1/4 and cyl4 at 1 1/2 turns out. Hope that is correct to make cyl4 richer.
With the throttle grip bogging down worse, I could change back the main jet from 97.5 to #90 and see if that helps. Another idea is change the needle from position #4 back to original #3 spot. I will replace plugs and work on the the fuel mix for the next few tries.
Ideas welcome.
