I have a 79 KE100, it runs perfectly for about 5 miles, then, when I'm going through the gears, it sputters and backfires like crazy. Once I'm at a pretty high and constant RPM, it runs fine. I just cleaned out the carb, so it can't be that. Once when it was doing this, I put a new spark plug in it and it helped out for like a 1/4 mile then it went back to backfiring and burping. I let it cool off and it runs fine. I never have a problem starting it, one kick all the time. I don't want to buy a coil unless I know it's definitely that because those aren't cheap. It only has 940 miles on it. So what do you think?
