1 - 20 of 111 Posts
Just picked up a 1979 KZ1000. 21,000 miles on it, and need to go through the carbs. The guys says he hasn't had it running in about 2 years, and when he parked it, he added a bunch of Stabil to the gas. The carbs are currently siezed, hoping it's just varnish, and can be cleaned up pretty easily.
I looked over the engine pretty close, and as far as I can tell it's not had any leaks. Not sure if sitting for 2 years would dry out any of the seals or not.
I'd suggest after you get the bike, to remove the sparkplugs and spray through the plug holes a good amount of PB Blaster. Re-install the plugs to keep out dust and Let it work for a few days to a week.
After a while,pull the plugs,remove the right side CD sized cover that houses the ignition pick up coils and using I believe a 17mm wrench, turn the engine over slowly checking for signs of binding.
Do not use the smaller 12 or 13mm bolt as it could shear off inside the engine crankshaft making for a "Fun repair".
I'd go through every electrical switch(except the ignition switch) and connector looking for signs of corrosion. I use a very good electrical contact cleaner/preservative called "De-oxit" made by Caig Labs caig.com - Home of DeoxIT - CAIG Laboratories, Inc. is their website.
Radio Shack and most other electronic supply stores carry this cleaner.
The handle bar switches,the electrical connections under the tank and inside the headlight housing wil need close inspection as they are out if sight and could be full of corrosion.
Picked up a '79 kz1000 a year and ahalf ago for $200 and the first thing I did was rebiuld the carbs. I ride it almost every day and I am SLOWLY restoring it. I put a $100-$200 into it each month as I find the part on Ebay (love Ebay!) I'm doing all the work myself so I'm learnimg alot!
Looks alot better than mine did when I got it. Mine was missing the side covers (still is) Header was rusted out Tank was dented bald tires seat was all duct tape (and I mean ALL duct tape) mirrors broke off handle bars bent and no turn signals. All I need now is the side covers and a little work on the tank and she'll be all pretty again. I even have new tank emblems ready. Hard to do on a buget but it can be done. Thank goodness for Ebay!
Discussion Starter · #11 ·
Is the oil cooler, an aftermarket thing on these bikes, or is it something that should be required, or even just recommended?
The last 4 cyl bike I had was a 1980 Honda CB650, and it never had one, nor really required it. Obviously this is a different animal, but just curious.
Looks like an aftermarket. It depends on where you live if it's needed or not. If it gets really hot or if you spend a lot of time in stop and go traffic it can be a good thing but these bikes don't really need one normaly and if you do have one it dosen't need to be that big and the positioning of that one is bad too.
GHOSTRIDER
You dont need an oil cooler unless your running her at redline for extended periods of time or long rides in 100+ degree areas. Synthetic oils resist breaking down at high temps better than the regular oils. Oils containing zink is the stuff these old big four KZs need :wink:
Discussion Starter · #15 ·
Hey Zoro,
I just updated the pics in the first post to ones I took last night. I have a few more from the tear down today to get the carbs out. They are locked up pretty good, and have carb cleaner soaking them now.
that bike will clean up...i dont know why someone orientated 1/4 vac plugs north...they definitely need replaced and send em all south.....the stock airbox is there......save that whichever way you go.....i would spray a can or two of carb clean on the exteriors and pull the tops and spray a can inside before i even tore those carbs open......pull the bowls and spray a can up in carb body also...let em sit for a day and then tear em open....just my .02....
A popular carb cleaning guide:
Carb Cleaning 101
By M. Shively
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, and adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
Why would you turn them all down when all the vacuum requirements are above them? It would require more vacuum line to reach anything that way.
i m not familiar with the 79 s and some of the changes from say a 78.....those two boots on 1 and 4 connect to what when the bike is back together?
1 - 20 of 111 Posts
