1 - 4 of 4 Posts
I have picked up a project 1980 kz 440. The bike is being turned into a bobber and this is my first bike build. With the frame work that was done there is not enough room for the stock air box to fit on the bike. I was able to get the bike to start and after idling for a few moments the rpm started ramping up quickly and turning down the choke kills the bike. I have been reading and watching a lot of discussion around the air box with the stock carbs but I am wondering if you are able to actually get the stock carbs to work without the stock air box or is it a waste of time and just swap the carbs out with a single mikuni carb and not mess with the stock ones?
A single Mikuni carb? Perhaps not impossible but very difficult to make motorcycles of that vintage work without an air box. Earlier non CV carbs were not a problem.
Discussion Starter #3
Yes I have seen videos of ppl using a 2 to 1 into a single carb and the bikes ran fine. Just wasn’t sure if that was the best route to go or if anyone had any other recommendations
Super Moderator
Have you cleaned the carbs yet? The symptoms you describe sound like gummed up carbs. I would be tempted to research what other 440 owners have done for re-jetting/needle settings when running pods instead of the stock airbox. Have the new jets on hand when you go to clean the carbs.
1 - 4 of 4 Posts
