1 - 4 of 4 Posts
:D Just bought one real cheap...Only 6000 miles and appears to be in good condition.Only problem is has been sitting for about a year.
bowls drain ok but gas really deteriorated.
Figured i would clean it out and cycle in the new gas.
Another problem is the bike is in neutral and the shift lever has movement but i cat get it into any gears.Thanks for any help.I hope i did'nt get burned. :wink:
also picked one up recently, same year, 1000j csr, and similar low miles, somewhere in here or another forum I read the clutch plates stick from sitting long time but can be worked loose without going into the motor.
1 - 4 of 4 Posts
