I can’t find and they don’t make the air cleaner element for this bike anymore part number 11013-044. This type uses a canister type filter and you couldn’t use a clamp on with this bike as the carb is down and on the side. What is the best solution. Thanks
I would try to fabricate an air filter. There may be youtube videos. If you have an old one, you could remove the outer filter material, then maybe cover it with an automotive air filter foam. I would use a 3M spray adhesive such as Super 77 or whatever is appropriate for the filtering material.
Sample search >> how to make a motorcycle air filter
