Hi,
I recently bought a second hand 1981 KZ750. This is my first bike, and therefore I failed to pick up the leak during my initial inspection. But I got a good price and the rest of the bike looks to be in great shape, so I'm not too ****ed off about it. And besides, part of my buying an older bike was because I wanted to learn how to maintain it and fix any problems that arose myself, so I guess I got what I wished for.
The problem is one of my carbs is leaking from its overflow tube, and I'm not exactly sure why. I assume it's because the float is faulty and is failing to close the valve that allows fuel into the carb, but because I'm not an expert and therefore a little reluctant to just blindly start pulling things apart, I thought I'd try to get some other opinions from other people in the know.
I have a video up on youtube that shows exactly what's going on:
YouTube - 1981 KZ750 - Fuel is leaking out of one of the overflow tubes.
As you can see, if I raise the end of the overflow tube above the level of the carb then the leak stops, but as soon as I drop it below that level fuel starts quickly leaking out.
Any thoughts or advice on how to further diagnose and fix the problem would be much appreciated.
Thanks!!!
Thanks!!!
