1 - 8 of 8 Posts
I'm going to be redoing my bike and would like to go with differant gauges for a couple reasons, reason one is that neither the speedo or tach work properly, reason two is that I would like to clean up my bike abit. One issue I've been coming across for the last couple years of trying to find a good speedo is that I can't find the ratio at the wheel... I found out that most if not all kawi's had the same drive, which would make me think that it's a concern of either the tire size and or the ratio of the speedo gauge... my bike came stock with a 18" rim where I'm finding out that most other bikes had the 19". I've found aftermarket 1:2 ratio speedo and 2240:60 ratio... so I'm getting really confused I don't know which ratio could be used on my bike if either... even if I went with a more normal 19" rim which one could be used... I would prefer to stick with the rim I have though. If I knew the ratio at the wheel than I could do some math and figure out what I need. Also I've only been able to find after market cable driven tachs, where can I get a electric one which is what came stock on my bike. Any info would be appreciated. Thank you.
So is the 2240:60 the standard drive at the wheel? and is that with the 19" wheel? Yeah I seem to have a habit of getting unusual or unique vehicles... '82 kz1000p, '74 ford maverick... so with my stock speedo drive (according to reaserch appears to be universal), and my 18" rim with a 110/90 18 tire, I should use a 2240:60 speedo? Thanks.
Or should I ask it this way... the 2240:60 speedo and drive would give accurate speed metering with what size front wheel? Thank you
Well according to the BuyKawasaki web site diagrams I checked out the wheel driven speedo drive and I hit the button to see what else there used on and it showed ALOT of bikes... most from that era, yet I think the differant models also had differant front wheel than the 18". What size front wheel is on your R1? 18 or 19? Thanks.
The original speedo gauge was really messed up you could hear gears being knocked around and the needle was broken so I went to a junk yard and picked up a speedo off of a newer cop bike, thing is though is that I found out afew days ago that cop bikes had a reducer/multiplier gear inbetween the drive and gauge... they had to have a more accurate speedo than civilian models. So that is why I want to goto something more conventional and cheaper than Kawasaki brand parts. Thanks
I've done some calculations but I can't find some kind of base point as to what the 2:1 or 2240:60 really means... I've calculated the tire revolutions per mile and devided that by what I think the ratio at the wheel is so I can get the cable rotations per mile... now what would I compare that to so I can the the speedo ratio? I think the wheel ratio is 15:9... with a tire diameter of 25.79" ... maybe I'm overthinking this thing.... I just want to know if a 2:1 or 2240:60 would work better with my bike. O'well who needs a speedo. thanks and sorry for annoying anyone.
1 - 8 of 8 Posts
