i got a prestige 1983 kawasaki kz440 with 900 miles on it & the bike is mint. the battery is an agm battery 2 years old. i keep it on a 1.4 watt solar panel in the off season to maintain charge. i have not started the bike in a while so i tried it today & the bike cranked for a few seconds then started to crank slow & then totally died. nothing on the bike works now the electrical system is totally dead & i tested the battery * it reads 13.00 volts. the solar panel also works & it tests at 20 volts. i kept the battery charged in the winter since the battery was new & the bile always started right up. i'm going to check the terminal connection this weekend to make sure they are clean & tight, but for now is there some kind of fuse/circuit breaker that could have been tripped to cause this issue? just wondering.
i also got a 1978 kawasaki 200 im prestige condition which fired right up & also is maintained by a solar panel.
