Maybe you need a newer battery tender and charger.
Copied with thanks from Federal Batteries website:
"Charging Considerations for AGM Batteries
Different chargers have different capabilities - Although under normal conditions most 12-volt automatic battery chargers will work on an AGM battery, the battery will only charge to about 80 percent of its full capacity. Many newer battery chargers have settings specifically for AGM batteries. Remember the technology of an AGM battery is not the same as a gel battery, which has its own charging requirements. If the charger offers different modes, select the correct one for your battery. Using the gel setting to charge an AGM battery will not fully charge and over time will actually damage your AGM battery."
