HI,
my 1984 GPz1100 A2 runs poor around 2000 to 2500 rpm. The engine abruptly stop running for a brief period and a tachometer jumps up. It doesn't happen when the engine runs without a regulator rectifier. The engine runs fine without a regulator rectifier. Have anyone experienced same or similar and what would be the cause?
I checked the regulator rectifier with multi meter following the service manual. It seems fine.
When I removed the regulator rectifier from GPz, I found one of yellow and ground (black) were burned at the connector. I replaced regulator rectifier and main harness couplers to undamaged one from my stock.
I checked ground wiring to see if there is brake / cut using multimeter. It didn't detect any resister or brake.
My GPz runs with stock DFI.
I am using a YUASA YTX20L-BS battery. I start suspecting the stock regulator rectifier doesn't work well with it.
Thank you!
Thank you!
