I did checked alternator and R/R today.
I did stator static test as the video from Kawasakian. The result is "Ol", no issues.
I also followed the service manual page 5-6 and 5-7 "Alternator Inspection". The result was 0.5 ohm which is in the range (0.36 - 0.54, according to the service manual).
I did not open the alternator cover for stator visual inspection today.
Rectifier inspection (Service manual page 5-7). No issues.
Regulator inspection test 1 (Service manual page 5-7 and 5-6). Light didn't lit. No issues.
I can't conduct the Test 2 because I don't have 24V power supply.
Regarding the battery. What I have is YTX20L-BS which is applicable for GPz1100 B1 and B2. I am using it since 2015. Before I bought the first one in 2015, I asked to Yuasa if there are any issues to use it to GPz1100A. Below is a response from Yuasa.
Originally KZ1100B (82 only) and 83-84 GPZ1100 took special battery for use with acid level sensor on dash board.
The battery was SYB16L-B. Which actually has since been discontinued. We say to use YB16L-B for these, and disable the sensor.
In these cases, and the other Kawasaki 1100 models that you mention, it is possible to substitute the YTX20L-BS.
Main difference (other than being AGM) is the width of the battery. YB16L-B was 100mm, YTX20L-BS is only 87mm. So you may have to add a spacer of some sort to keep battery from
moving.
As far as charging system requirements ...
And time you are changing a conventional battery, and using an AGM instead, you should check capability of your motocycle's charging system.
At 2,500 - 3,000 rpm, you should see at least 13.8 volts to be able to maintain the battery decently.
http://yuasabatteries.com/faqs.php?action=1&id=30
If voltage is lower, or bike is not consistently run at those RPM's (highway use), you may need to supplement the charge on the battery to keep it 100% charged.
This means periodically putting the battery on a maintenance charge. At least once a month.
Putting an AGM in an older application will not typically shorten the life. In fact, you will probably still get longer life out of an AGM, as they are designed to last longer overall,
As compared to a conventional battery that has an average 2-3 year life.
After I revisited it, I have feeling that using YTX20L-BS is not the cause... I need to recharge it before I do testing though...
My GPz's battery sensor was disabled by the professional 20 years ago (It could be more 20years. I don't remember...
Next move will be stator visual inspection, to find out how I will have Regulator inspection test 2 and wire harness check.
