I had an issue two weeks ago where my throttle stuck wide open. I thought maybe the cable broke but it is in good condition. I pulled the carb and realized that the cap was loose and the throttle sleeve came out of the bore. the needle stuck in there sideways causing the bike to go wide open. I pulled the carb apart replaced the broken needle clip and put if back together, needle is set on the top notch. Everything seems fine but the idle is way too high. I have tried adjusting the set screw for the idle but it doesnt change. Seems like the throttle will not setle down in place at idle.
Any sugestions?? What am I missing?
