Hi,
I am hoping someone can give me a touch of advice. I have the above mentioned bike and I'm not sure if I part it out or fix it. I have looked for the electrical parts i know it needs and find all but the main relay. Is there a way to bypass the relay to find out if the ignition/checks out? It has no carbs so I dont want to spend a ton if the electrics are shot. Pick up checks out stator is good. Also I think the fuse box may have had some water in it at one time can the circut board behind the fuses go bad because of this?
and if any of you know where I can find a set of carbs? the ones I got with it are for the 750 and wont work.
Thanks and I hope I've given you enough info (I read the please read) and yes I use a multi meter!
rskybiz
rskybiz
