I just purchased a 86 Bayou 4 wheeler. It idles fine, and if you just give it a LITTLE gas it will rev up a little. But if you give it anything over 1/4 throttle, it acts like its hitting a rev limiter... It pops, backfires... Its not the carb. It has been rebuilt and everything in in good shape there. The coil has been replaced, the spark plug has been replaced, and the previous owner said he replaced the CDI box and that didnt help either. So, im assuming its the pickup coil, or possibly the stator?? I tested both as it told me to in the manual. Both tested fine, but that was with the engine off. It idles fine, so im not suprised that they tested good with the engine off. Is there any way to test them with it running? Does this sound like a bad pickup coil, or stator?? Any help would be appreciated!!! THANKS
