According to CMSNL.com, these carbs are unique to the H1 model, so unless you’re prepared to try alternatives, you’re going to have a tough time.
CMSNL.com
Just my luck. I will just have to try and get the best OEM Carb assembly I can.According to CMSNL.com, these carbs are unique to the H1 model, so unless you’re prepared to try alternatives, you’re going to have a tough time.
That would be very helpful mate. Thanks.I know from experience that the H1 and H2 carbs are different. That’s not to say that the carbs of the H2 (or J or L for that matter) wouldn’t actually fit and work well.
I’ve got some ZX6R carbs on the bench that I’d be happy to take measurements from to see if they would also fit your bike. They aren’t for sale but it may open up your options further. The ZZR600 carbs are also very similar.
Thanks for that mate. Very helpful.The inlets are spaced at 75mm between centres, the cable take off is on one side. Each inlet is 36mm inside diameter
These are Zx6r carbs, zzr600 carbs are very similar but with a central cable take off so the spacings will probably be slightly different. View attachment 46492
