1 - 2 of 2 Posts
Does anyone know what these should be???
I can't make any details out on the bearing sides, and i have tried bikebandit.com which gives a number of 92046 for the main swingarm bearings and the bottom of the dogbones (which i also want to change!), although they dont appear to be the same size physically..
I'm waiting for a clymer manual, but if anyone could tell me what the bearings should be i'd be very grateful...
aygee
hmm
that clymer manual wont tell you anything:)
PN 122250 for dennis kirk.
has seals, bearings and spacers and thrust washers. 44 bucks.
that 92046 is more then likely the first 5 numbers for the part number. the last numbers are the one that will give you the bearing size unfortuantely
there is also a linkage kit but its about 85 bucks, if your not gonna redo the whole thing id go to the dealer and get some bearings if you can. but more then likely if your asking all your needled bearings are probobly dust so you will probobly need more then just that.
1 - 2 of 2 Posts
