I have a 1990 Bayou KLF300 ATV that charges normally at an idle but erratically discharges as rpms are raised. Also, the black w/yellow stripe wire at the battery negative terminal becomes hot. How do I troubleshoot this?
Discussion Starter #3
get the service manual out and start digging
could be a lot of things causing it including but not limited to bad ground
Thanks for the advice. I looked over the electrical schematics and ended up cleaning all connectors on starting and charging circuit, replacing corroded solderless connectors and cleaning grounds. Appears to work normally. Thanks again.
