1 - 7 of 7 Posts
hi there
my name is steven and i reacently took apart my enigne and i need the torque settings for the cyclinder head and gear box cover.
if you know what they are please tell me
or
if you know where i can get them on the internet that would be great
thanx :)
on old bikes like mine torque specs for stuff like the head don't much apply since there usually is some warping ect, so I just over tighten with short hand box end. Then recheck after running.
Just put it back together if you can't wait.
per Clymer Manual: 1991 KX125
Cylinder Head Nuts 18 ft-lbs [25 N*m] (Bolts same if applicable)
**Tighten them from center first then criss-cross pattern outward**
I don't know what you mean by gearbox cover, but I will guess you mean right-side engine cover and clutch cover. There are no specs given for those M6 (8mm head) bolts. I have always used a T-handle or small ratchet and just get them tight by feel.
Here are the other clutch-side torques:
Clutch Nut (Center of clutch hub): 72ft-lbs [98N*m]
Primary Drive Gear: 43ft-lbs [59N*m]
Drain Plug: 14.5 ft-lbs
Return Spring Pin Locknut: 14.5 ft-lbs
Shift Drum Plate Bolt: 16 ft-lbs
torque specs clutch cover 92 kx 80
can someone real quick gimmie the torque specs for the clutch cover on the 92 kx 80 ...right on bros
1 - 7 of 7 Posts
