I've been having trouble for some time with starting both of my bayou's after they have been sitting for a while. Each time is a real challenge. Sometimes I use the choke and sometimes not. Doesn't make any difference one way or the other. If it is going to start, it will start right away. But if not, I spend an hour or so pulling the plug and cleaning it and playing with it till it will start. The plug is usually wet (with gas) and black. The plugs have always been black since I purchased them. I pulled both carbs and cleaned them and also have put fresh gas in but this doesn't seem to help. When I pull the plug and clean it I always check for spark and there is a good bluewish white spark. The air cleaners are slightly dirty but not extreme. They don't seem to start any better even when the air cleaner is completely removed (just for starting of course).
Has anyone had similar problems? Any help is appreciated as I'm getting very tired at fighting this everytime they have been off for a while. They seem to start the next day ok but if they are left off for a week or two then the problems begin.
Thanks.
SB0368
Thanks.
SB0368
