1 - 9 of 9 Posts
hi should there be any movement on the shaft that thefront sproket goes on its not up and down i can pull and push it in and out i reckon theres about 3mm of play if not how do i fix this
Logically, yes, my reckoning is that when you hit a bump its subject to ALOT of G Force so it needs some tolerance because if it was locked in one position it would break real easy, but honestly I dont know!
I think theres about 3mm of inward-outward play on my 125s, i'll check that.
Yep, roughly 3mm tolerence, so if its wrong then i'm buggered to
Discussion Starter #4
thanks i have a manual cant find it though ill need to look and see ill let you know i assume the 125 cant be much different from the 250
My 2001 KX250 does the same thing. I'm pretty sure it's normal. Just a little play in the gears is all.
I think as long as it doesnt move front to back it is fine. If it moved front to back, that would signal a bad bearing, and would shorten the life of you chain and sprockets.
Discussion Starter #8
the reason i ask is that i had a prob with my bike not staying in 4th the dogs were worn i undercut them though because new ones were far to expensive im worrying that that play would cause it to pop out as well as 4th gear is on this shaft
Discussion Starter #9
i looked at manual cant find anything about it in it ill have to contact local bike shop
1 - 9 of 9 Posts
