1 - 2 of 2 Posts
I took my battery out to clean the terminals when I reconnected the battery and push the starter sparks are coming from the negative battery terminal. No other mechanical sounds are noticed. All fuses are good.
Super Moderator
Test that the connection is tight. Grab the wire(s) and try to wiggle them.
Also what did you clean the terminals with?
1 - 2 of 2 Posts
