1 - 2 of 2 Posts
Went for a ride this morning discovered my back brakes weren’t working. Opened her up the reservoir was bone dry I filled it up and loosened the drip valve but the fluid doesn’t seem to be pumping through there anybody know what’s going on with this thing?
Super Moderator
Substantial loss of fluid indicates a leak somewhere that will need to be fixed, but in the meantime are you using the proper bleeding procedure? Also if the master cylinder ran dry, it may need to be bled also. Loosen off the master cylinder banjo bolt until you see fluid there.
1 - 2 of 2 Posts
