I just bought a Vulcan 1500, I was told about a shifting problem ( it grinds when shift from 1st to 2nd ), I took apart the engine, checked the gears , drum, etc. The only thing I found was the Return Spring bolt bended.
I replace the bolt, put everything back, and adjusted the shift linkage rod.
But still doing it, when I shift from 1st to 2nd it will grind, if I shift at 17 miles like Kawa. specified it will not grind but it is not enough speed for the 2nd gear, the higher shifting speed the worst it gets, to the point that it will jump to neutral.
If anybody has any info. please let me know.
Thanks.
Thanks.
