Hello all!
New to this forum, so hope I'm doing everything correctly.
I recently bought a beater Kawasaki Eliminator 250, I checked it running once I got home and the motor sounded great. The only issue was that it struggled to run. I could run it to the end of the street and back, but if I rolled off the throttle, it would stall. I could only start it on full choke (even warm) and run it on half.
After taking out the plugs, running a compression test on both cylinders, and inspecting the plugs, the fault ended up being that the spark plugs hadn't been adjusted correctly. I replaced these with new plugs anyway, as well as oil (only had 15w/40 for cars, so I put that in, read that it would be fine as a temporary alternative but clutch may slip. I replaced this with motorcycle oil the next day after running only once). After changing the oil to motorcycle oil again however, my bike has developed a loud knocking sound almost instantly. I made sure to keep anything away from the spark plugs holes while they were out, so that nothing dropped into the cylinders; almost certain I succeeded in not turning my cylinders into a temporary pinball machine for a bolt or nut.
Here's videos of the bike running:
Video 1 -
Video 2 -
I've checked the exhaust bolts, checked bolts located on the top end too. All were tight.
Noise doesn't go away when I pull in the clutch so its not the clutch housing as I'm aware that this is a common issue with these bikes. Clutch engages just fine.
Bike doesn't idle amazingly, but doesn't stall now. I've adjusted the idle screw still to no avail.
I'll check to make sure the new spark plugs are an exact replacement tomorrow as I replaced them with another brand, though I assume if the piston was hitting the spark plug, that cylinder would stop working.
Is there anything I'm forgetting to check before I assume this is a buggered top end? Just want to rule everything out before pulling the engine apart.
Video 1 -
