1 - 4 of 4 Posts
Kawman
Is it a 1500 classic, or a nomad, or what? Does it have both exhaust pipes exiting the engine on the right side of the motor or does one exit on the left? If both exit on the right the starter is on the front of the engine below the cylinders.
Custom '07 1500 Classic
It's underneath the outer plastichrome cover then you have to remove the stator cover... Both are on the left hand side of the motor. If you remove the stator cover you will need to replace the gasket, part number 11060-1122. Be ready to catch the oil thats going to pour out when you remove the stator cover as well.
1 - 4 of 4 Posts
