frt Ujoint
It is supposed to be easy to put in a ujoint in a mule, I have and it's not a prob. Have you ever put a joint in a drive shaft or ?.
You should get a repaire manual from your dealer it will be a good investment. If there isn't any rust on the pinion shafts all you do is
remove bolts from hanger bearing and any thing that is in way of
slideing hanger over to one side and pull drive shaft from rear diff
than pull shaft apart. Now you can pull the frt part from frt. diff.
Than go to your vise and have at it. Bob
