1 - 14 of 14 Posts
On left side or motor there is a big plug in center and a little plug to the back and up a little bit will some one tell me what oil goes in there just got bike no manuals pls help
Super Moderator
Search the mfr's website, I'll bet you can still download an owners manual for free.
Discussion Starter #4
When I down shift it grows and I was wondering if gear oil mite be low
The Plugs you refer to are for Timing the engine.
Do NOT put oil in either orifices.
Large plug gains access to a 14mm bolt to turn the engine.
Small plug gains access to the timing marks.
Hard to diagnose unless I could ride the Bike and experience the noise.
So
First thing I would do is check the Final Drive oil level, Inspect the Bevel Gear teeth for wear then change the oil.
Front Gear Case is not as easy as it's oil fed from the Engine.
Both front and rear gears are shimmed for backlash and can be noisy if out but you need special tools to do the job.
How many miles has the Bike done ?
Discussion Starter #9
If the sigils do you know the part number for Front bevel gear bearing
Discussion Starter #11
Thanks for all you Help What kind of oil goes in to the bevel Gear case
1 - 14 of 14 Posts
